    Results 1 to 12 of 12
      Jul 2003
      Anaheim Hills, CA
      After a long delay.. Project Update
      Since Seattle's weather has moved down it rains all the time. This has made it very hard to make progress on the car. I finally got sick of waiting and dodged rain clouds to get to the shop.
      So what did we get done? Well, lots of little things like wiring guages, tightening bolts and other minor things. The two big things were:
      drum roll....
      Fabricated the intake. It came out nice and we welded some clips on the bottom to hold the wire loom all nice. We did need to modify the radiator inlet so that we could get the best looking angle on the tube but it all worked out well. It's going to be thermal ceramic coated to match the headers.
      Also we installed the Slide-a-links and the QA1 rear shocks. The moron I bought the car from had the drivers side leafspring in backwards -- other than that the install was pretty straightforward.
      Car ran great on the freeway going there. Now that the guages are hooked up I can tell the car runs very cool. When cruising I never got over 150 and in traffic I barely touched 180 degrees.
      And this pic just because I like it:
      Next up.. final paint and buff (a small adjustment is needed to the drivers door). Then it's off to interior.
      A light at the end of the tunnel?
      1968 Track Rat Camaro:
      Jun 2002
      Long Island, NY
      Nice work, Steve!! That is one awesome Camaro, keep us posted on the finishing touches.
      Apr 2004
      Yuba City, CA (bout 1/2 hour north of Sacramento)
      Steve,
      WOW! would like to say more but I cant stop staring at ur car!
      J.T.
      Burnaby, BC, Canada
      Looks awesome, as always Steve....
      1969 CAMARO RS
      Project pics of my '69
      Lateral-G Feature Page
      Mar 2002
      Redwood City, CA
      It's missing some lights in the front. What's up with that?
      Allen Ortega
      Red Deer, Alberta, Canada
      Cars looking great Steve! I really like your idea of welding clips on the bottom to hide the MAF wires.
      -Matt
      Matt
      Instagram: Cst_koon
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by protour_chevelle
      -Matt
      To be technical we welded threaded studs so we could bolt on small clips. I will try and take some detailed pics this weekend. If you look close at the intake you can see the tubular post we used to support the outer end of the intake. It goes straight down to the fenderwell where it uses a factory hole. We also put a rubber gommet in the hole to act as an isolator.
      Yorba Linda,CA
      Steve, Where's the driver seat you promised me?
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by LS1Z28
      I picked it up Thursday and it's in my garage. Good thing you are recovering it because they left it outside for a couple of weeks.. Oh well, you can't beat the price, free
      You can come by this weekend and pick it up.
      Cumming Ga
      ? about your upper shock mount
      Did you mount your upper rear shocks in the stock trunk location?
      Shocks are still on my "to-buy" list, but I installed Slide-A-Links and a CE upper shock mount to move them inside the rails. I was planning on using the Slide-A-link's lower inner mount and of course the CE mount for upper. But with this configuration, things will be tight when it comes time for exhaust!
      Feb 2003
      St. Louis, Missouri
      Nice 'maro Steve.....where'd you get them traction bars? Might need some for my 67.
      Apr 2004
      OKC, OK
      Very nice car. It is still one of the cleanest I have seen and I love that blue on your car.
      Mike
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
