      Mar 2003
      Petaluma, CA
      one touch down windows
      Is anyone running this type of system in their car? If so, did you modify an existing door module from a newer car, or was it part of a kit?
      Thank you.
      -Jeremie
      Melbourne, FL
      Most people who have adapted this type of setup grab the complete setup from a donor car. Search this thread for a guy who did this on his 67/8 F-body with parts from a caprice I think.
      north central Iowa
      I think you can upgrade the kits at www.autoloc.com for this feature.
      Mar 2003
      Petaluma, CA
      Thanks for the replies, I have a few ideas that might also work. If I recell correctly most of the logic and the relays are built into the switch, so it might be easiest (and cheaper) to find a swtich set I like and look for one in a wrecking yard. one touch down and up would be REALLY nice to have.....
      dennis68 Guest
      Dodge Durangos use a 1-touch switch for the driver window only. It is a fairly small switch and could easily be incorpoarted into just about any bezel.
      Dunwoody, GA
      i know for my 96 the switch is the same whether you have auto down or not. theres a module that controls the auto function. heres a write up on making the passenger side window an auto down. maybe this info can help some how.
      http://www.bfranker.badz28.com/fbody/expresswindow.htm
      Trey
      ~ Jon Hammond
