    Results 1 to 20 of 29
    Thread: 700hp na LS7
      Chicagoland
      700hp na LS7
      We got to 690 hp today on BP pump premium fuel, idles smooth at 920 rpm.
      Stock plastic intake, stock DBW throttle body, Tuned GM Corvette ecu, Custom Cam, head work, Schwartz MAF.
      Maybe we'll hit it tomorrow, 2 more LS7's with different parts to test
      Videos soon.
      Jeff Schwartz 815-770-0751
      SchwartzPerformance
      Where classic style meets modern performance.
      455 Commanche Circle
      Harvard IL 60033
      SchwartzPerformance.com | Facebook | Twitter
      Amazing numbers Jeff.
      Andrew keeps telling me that the factory ECU is the way to go. We gotta talk about a engine/transaxle combo some day...
      jp
      ​John Parsons
      Batesville, IN
      Man - that's impressive. Sounds like your having entirely too much fun!
      Keep up the good work!
      Brandon Wiedeman
      1972 Suburban
      Wiedo's
      Chicagoland
      Made 730.7 hp today with same cam, slightly different combo. Schwartz Power Spacer, Short Ultima headers, 3" collectors and exhaust.
      SchwartzPerformance
      Harvard IL 60033
      Atlanta GA
      now if only i could afford it..
      ahhahaha
      Jul 2001
      Detroit, Michigan
      Damn Jeff. LS9? Who the hell needs an LS9?
      1968 Pro-Touring Camaro LS1
      Project: Next Year
      - Start date; June '01
      Chicagoland
      Quote Originally Posted by trapin
      Exactly!
      My old 500 hp LS6 with a 150 shot would take a new ZR1
      SchwartzPerformance
      Harvard IL 60033
      Feb 2006
      Quote Originally Posted by jeff s
      Exactly!
      Wow thats some statement, what kind of car was this in? I hope it trapped 134+
      Quote Originally Posted by KILLER06MUSTANG
      haha...
      http://www.schwartzperformance.com/alien.htm
      Miamisburg, Oh
      Awesome work Jeff!! Congratulations!
      I'm glad to see you testing things out because I still hope to get an engine in the coming months. The choices make my head spin.
      Aug 2006
      Chantilly VA
      Hey Jeff,
      What's your thoughts on these cam specs for a LS3
      • Lift .591 .569
      • Duration 230 226
      • Lobe separation 112 with 4 degrees advance
      On another note how do you do so many different aspects of car building so well?
      I am always impressed with the stuff you produce. Keep up the good work.
      69 Firebird, Caged, Minitubbed Ls3, TKO 600 Morrison Subframe- G-Bar Blah Blah
      Aug 2006
      Chantilly VA
      I'd like anyones opinion. I am kind of new at this.
      Quote Originally Posted by quiksilvr
      Hey Jeff,
      • Lift .591 .569
      • Duration 230 226
      I think an LS3 would favor more of a traditional split cam as opposed to the reverse split listed above. The LS3 heads flow great on the intake but the exhaust is a little lagging. So a cam with more exhaust timing and lift is prefered from what I understand.
      Chicagoland
      I've tested numerous different combinations of intakes, intake mods, camshaft profiles, etc. More that 100 pulls on the dyno.
      Spent thousands of dollars testing. (all on LS7's).
      Video and charts coming as soon as I get a chance to load it into my computer.
      I dont like those cam specs for an LS3, what Andrew said.
      SchwartzPerformance
      Harvard IL 60033
      Aug 2006
      Chantilly VA
      Thanks guys, I've got a lot to learn.
      Miamisburg, Oh
      I agree with them too.
      I thought the LS3 used the L92 heads and that it therefore would need a sizeable amount of extra exhaust duration. (given same lift)
      I'm just going from recollection though,.....I should take better notes.
      69 RS
      LS7, T56 and other cool stuff
      Back on track in late 2020!
      Build Thread
      Jeff
      the only way I know of to compare "streetability" over the internet is to compare idle vacuum@rpm.
      So, if and when you post information on these setups, I'd be real interested in hearing those values.
      I get so tired of magazines claiming "streetable cam" when they're running .6xx+ lift on the cams.
      In my experience, 12" < 1000 rpm is "streetable", but you can't really call it "vette quality streetable" for the average older guy souping up this car unless you have more like 15".
      Although that has nothing to do with what some guy in a super Ultima or trying to set records might like.
      Jeff,
      Im chomping at the bit here, wheres the vid and numbers? Very interested in an LS7 with 600 rear wheel ponies that idles like a kitten.
      Rich
      Chicagoland
      10" of vacuum at 920 rpm on the 730 hp. Where it idles nice.
      It's 12 around 1000. We have 3 different cams, depending on intended use. (desired vacuum)
      Of the 27 modified LS7's I've done in the past 12 months, none were for Corvettes.
      We're making DVD's for the 5 customers, who's engines these are. Once they have the DVD's I'll post video, couple more days. Link to charts: http://gmachinechassis.com/dyno
      SchwartzPerformance
      Harvard IL 60033
      FL and Calif.
      Thank you Jeff for updates. I am allso looking for a real life streetable cam for "heavy" weight camaro. So i would appreciate good idle and vacuum. Do you have below 700 hp cams ? If so what kind of hp numbers and idle ?
