    Thread: WS6 Input
      Nov 2004
      WS6 Input
      Does anyone sell billet hood scoop inserts or nostril inserts for a '99 T/A - WS6? I saw some from HPA Performance, but they look like they are out of business.
      I recently purchased a FAST 78mm throttle body. I also have a V-ram velocity stack. Should I put this in the new throttle body?
      I have reprogrammed my computer with the Hypertech programmer. What kind of advise would you have on transmission shift points and shift firmness? The car is being used just for street driving.
      Feb 2003
      Houston, TX
      You might try asking those questions on the appearance forum at www.ls1tech.com
      The velocity stack is designed for stock t-bodies. Don't use it on the new one.
      shift points: as close to 6200 rpm as possible. You will have to raise the limiter a bit to keep from hitting it, maybe up to 6400.
      Co-Founder, LS1TECH.com
      www.DV8Motoring.com
