      Linwood,NC
      LS2 camaro dyno results
      Today I got the camaro dynoed, I am really happy with the results. The motor is basically stock with a cam,underdrive pulley, and Hooker 1 3/4" headers. I put the video in the multimedia section.
      Cam specs: 238/240 .605/.609
      Dunwoody, GA
      any chance you have a before cam and after cam? I think that would give people a better idea of the changes. Looking good so far. Drop some ported LS6 head on that thing or step up to some 225 AFRs or Trick Flows. You'll really bring the life out of that thing.
      Trey
      ~ Jon Hammond
      Maine
      Nice!
      Did you have to tinker with the computer settings when you swapped in the cam?
      John
      Dunwoody, GA
      That cam requires tunning.
      Trey
      ~ Jon Hammond
      Linwood,NC
      I don't have any before and after results, but a stock GTO makes about 355hp to the tires.
      It did require custom tuning to get the driveability dialed in.
      I agree, heads would probably add 40hp more to the dyno numbers.
      Not bad! I'd check out our Precision Race Component heads to boost that bad boy up towards the 475rwhp mark! A set of the Stage 1 5.3L or LS6 heads would make a nice addition of power (and the 5.3L heads would boost that compression up some more and help the torque situation a bit too with their smaller chambers!)
      www.texas-speed.com and check out the engine/valvetrain section for some deals on these heads!
