Results 1 to 13 of 13
- Nov 2007
- 266
something wrong or am I just lucky?
He I had a pair of c5 discs delivered to the shop and I was suprised to see that they appeared to fit perfectly on my hubs without having to machine the hubs at all. They sit flush on the hubs and the center doesnt seem to cause any problems either. Everyone says the have to machine the outside edge of their hubs but I have ample clearence the way it sits. So did I mess up or do I have the only set of hubs that will fit a c5 disc with no problems????
01-29-2008 #2
- Nov 2007
- 266
i assume this is normal?
01-29-2008 #3
- Jul 2006
- Chesapeake, VA
- 678
What car? It's my understanding that most if not all 5 lug Chevrolets down through the years use the same pilot hole diameter as well as the same lug spacing so there you go.
01-29-2008 #4
- Nov 2007
- 266
What Im talking about is the outer diameter of the hub. Every place that sells C5 disc brake conversions says that you need to trim down the outer lip of the hub to fit the inner face of the C5 rotor and apparently it wasnt necessary on the hubs I have so I was asking if this is some strange coincidence or if something is wrong cause i didnt have to trim the hubs.
01-29-2008 #5
