    Thread: Ls1
      Oct 2006
      Norway
      Ls1
      I'm new into the LS game. Could someone have a look at this ad for me. Seems like to many parts is missing. Shifter, clutch/ flywheel parts++++ are these parts hard to get or shall i give him a bid on the motor only. Is it better to find anothe "package"
      Here it is:http://www.nastyz28.com/forum/showthread.php?t=108738
      Olav
      Den Helder, the Netherlands
      Country Flag: Netherlands
      Do you have a link for the ad, Olav?
      Oct 2006
      Norway
      Opps I add it :-
      Olav)
      Feb 2007
      i would offer $2500 for everything including trans.if he says no,pass on the transand atleast get the motor.
      if the trans ended up not working right you are going to spend a few hundred having it rebuilt.i've seen complete trans packages with hydrolics,clutch,flywheel,etc sell or around $1500.
      CT
      That set-up is also being sold here
      Oct 2006
      Norway
      The seller doesn't know if the harness and ECM is for a stick or auto trans. Is this a problem ?....... or is it better to find a complete package. Since i'm living in Norway and we NEvER have parts/cars for this motr/trans at junkyard I'm afraid that parts are missing.
      Olav
      Jul 2001
      Detroit, Michigan
      I don't believe that's a problem. You're PCM can be programmed as a manual or an automatic. It's all in the software.
      $2200 would not be a bad price for that. '01's have the LS6 intake (which that one has) so that saves you one less item to buy, or if you're converting to carb you can get a couple hundred bones for the LS6 intake easy. However, that mill looks like it has more than 33K on it. Unless it's been stored somewhere damp and dirty for a couple years.
      Do a compression test on it just to be sure. Worse comes to worse you just have to freshen up the bottom end. And that's just the cost of some new rings and bearings. LS1's are tough little critters.
      1968 Pro-Touring Camaro LS1
      Project: Next Year
      - Start date; June '01
