    Thread: paint needed
      paint needed
      how much paint material would i need to purchase to paint a complete car.the color will be 1969 camaro fathom green. i intend to paint all the jamb areas, under the trunk and stuff like that.
      how much paint, clear coat, and other paint stuff would i need.
      thanks guys
      1 gal of un mixed base coat, 2 gal of clear, 2 gal urethane primer or 1 gal ureethane and 6 qts poly,2 gal filler, lots of sand paper
      Sep 2007
      Elizabeth City NC
      I would check with whoever you are getting the paint from some colors cover different with different paint manufacturers but usually a gallon of unreduced based with do a car outside and the jambs. as far as the clear depends on how what you want it look like when its done a gallon + reducers/hardners will usually do a basic paint job if you plan on reclearing and wetsanding flat and such you will probally need 2. sandpaper- alot/ different grits primers again it depends basic a gallon should do you if you plan on blocking and repriming and blocking again go ahead and get 2. paint gets pricey but you will soon find that out with your bill
      67 camaro
