Results 1 to 1 of 1
Thread: 31 Spline Strange Axle seal
New to Pro-Touring
- Jan 2008
- 2
Hi Guys,
Kind of new to installing axles. I've been reading the fourm and I think I need to use an axle seal along with the Strange bearings that have the built in O-ring. Seems if I don't use the seal many of you guys say that the leaks will happen. So does anyone have a part# for the right size seal? I have EARLY BIG FORD HOUSINGS. I also want to double check that when installing the seal I'll want to silicone it in. Right? Should I silicone around the o-ring that's built into the bearing as well? Man Thanks for the help.
Thom
