Results 1 to 20 of 21
Thread: Steel vs. Aluminum Air tanks?
01-22-2008 #1
I am in the planning phase of a full AirRide suspension for my 2002 SVT Lightning and want to keep the weight to a minimum, to that effect I have seen ART has Aluminum tanks, but upon asking around I have heard they can be a saftey risk due to the fact they have no "GIVE" like a steel tank, and will simply explode in a gloriously destructive plume of shrapnel......
Any truth to this?
Thank you in advance for the input,
Ian
01-22-2008 #2
Full Blown G-Machiner
- Aug 2004
- Boston MA
- 686
I don't see steel having more "give" than AL. That said, a pressure vessel is a pressure vessel. Its either rated and sold for that application or it's not. Seems like an odd place to try and save weight. What's the weight difference and why do you want to save it?
1967 #s RS
01-22-2008 #3I do not have specific numbers but the steel tank would be around 20 pounds vs. the aluminum tank at about 7, plus the added benefit of corrosion resistance.
It will be mounted in the bed and when dealing with making a 4700 pound truck work on the road course it helps to shave every pound possible, it does add up in the end.
For example I am saving nearly 100 pounds with the tubular front arms and power rack and pinion conversion.
01-22-2008 #4
- Oct 2007
- ridgefield ct
- 876
i figure that if air ride is selling the aluminum then you're safe. if it's some no-name chinese tank i wouldn't trust it.
01-22-2008 #5
- Jan 2006
- Oregon
- 1,773
