Results 1 to 18 of 18
Thread: welding copper
- Aug 2004
- 830
welding copper
Any body know any thing about welding copper? should I TIG or gas weld? nothing seriously structural but I don’t want the welds to crack under high vibration
what should i use for filler rod? Can i use a thin strip of the metal I’m working with and weld it with a oxy torch? I plan on planishing the welds flat
01-20-2008 #2
- Jun 2005
- 543
I don't know much about welding copper. It burns at a very low temperature and is a very soft metal. I do know that you can solder it, which means you can probably braze it as well, provided the material is thick enough.
Originally Posted by RobM
Perhaps it would be helpful if you let us know more about what thickness of material you are welding and what you're looking to do more specifically?
Mathius
01-21-2008 #3
