    Results 1 to 9 of 9
      700R4 converter lock up?
      Having Trouble w/ the converter staying locked when in 4th gear?
      Any ideas?
      Aug 2005
      Patterson, NY
      Is it not staying locked, or is it not unlocking?
      its not staying locked...
      Aug 2005
      Patterson, NY
      What are you using for a controller? Does it have a vacuum connection or a TPS connection?
      i dont know to be honest, i had the transmission put in last year is a conversion from a turbo 350 on a 72 monte carlo. i think it is a vacuum connection there is a lead wire running from a switch on the diver side to a hot, this is the only electrial item i see?
      Jun 2006
      Indianapolis,IN
      What are your shift points. It should lock up with the switch on at about 48-50 MPH. 700R will getting sloppy if the detent is adjusted incorrectly.
      Tim
      it will lock @ crusing spead as you said around 50 mph ..but will not stay locked will jump in and out i can see it on my tack and fell it lock and un lock
      Have you had a chance to see how the switch is wired? If there is only one wire coming up from the transmission and hooked up to a flip switch, then you need to check your connections. If the connections feel tight and look good, you could have a solenoid cracked. The converter clutch solenoid cracks at the plastic snout where the check valve seats. (you will not see this unless you disassemble the solenoid) If you you have a vacuum switch, then you need to check vacuum lines very well and the connections. Let me know what you find I will try and help you determine the problem.
      If you need to replace the system check out Bowler Transmissions Lock-up module.
      Thanks Will Get To Work
