    Results 1 to 7 of 7
    Thread: Header Dinger
      Header Dinger
      Alright guys I'm about to tackle the steering on my car and was wondering if anyone witha big block has found a way to get headers on with power steering.Everyone local says i have to dent the header to do so but thats out of the question.I'm not about to spend big ching on ceramic headers just to destroy them.Does the steeroids kit take care of it?
      Jan 2002
      Crockett, Texas
      Hedman 68198
      First gen Camaro?
      If so, the Hedman Elite #68198 (1 3/4" X 3 ) headers will clear the PS box if the correct frame stands and motor mounts are used.
      Here's proof:
      Don 67 Camaro RS/SS Texas
      which mounts for header clearance?
      Quote Originally Posted by ZZ Top
      First gen Camaro?
      Which frame stands and mounts are needed? I'm getting ready to drop a 383 into my 68. The original engine was a 327. Which stands and mounts will make my life easier? Any chance I can re-use the original 327 stands with 350 mounts?
      Salinas, CA. 4.5 MI from the Corkscrew @ Laguna Seca
      Your small bock mounts should be fine. I found out the hard way you cannot mix Big block mounts with small block and vice versa. Stay with the small block frame mounts and you should be OK. .bber
      Jan 2002
      Crockett, Texas
      David Pozzi's site/
      68driver, David has some great info here
      http://ourworld.compuserve.com/homep...aro_engine.htm
      First gen Camaro?
      Here's proof:
      What stands and mounts are you using? I bought the elites part #HED-68278 (small block) I had to beat the crap out of the tube to clear the steering box. It is a quick ratio box.
      Jan 2002
      Crockett, Texas
      In those pics, everything there is original 69 Camaro SS 396 stands and mounts.
