    Thread: cam questions ?
      Nov 2004
      livonia mi.
      cam questions ?
      hello . I have a 355, 10:1 KB with world s/r 2.02 heads,comp 272 cam, rpm intake, 650 dp. carb , M21 4 speed , 3.73 gears & 26" tires. I've got a free new cam. a crane H-228/3200-2s-6. specs. @ .050 duration is 228/234 , lift is 480/494, lobe center is @ 106. is this to much cam for my combo ??
      Mar 2002
      Redwood City, CA
      You may find that you will need a bigger carb, but it should be ok. Maybe a porting job on the heads too. It doesn't sound too big, but I tend to be a little conservative on decisions at times. I should give you a nice bit of top end. What's the lobe separation on it? I'm too lazy to do the research.
      Allen Ortega
      Aug 2003
      Not to much at all. With 106LCs it will be a rumpty rumpty little cam. With those heads you are easily good to the low [email protected] range.
      Nov 2004
      livonia mi.
      its @ 106
      Mar 2003
      Boringville
      yes, that cam will match your combo just fine, better than the (what i assume is) the old comp 272. Like prodigy said at 106 it will be a loping idle and have a lot of snappy of the line torque. Are you sure the LSA is 106 or is that the ICA? Personally I would ditch those heads or have them ported. THey aren't any better than a set of stock double hump heads. But if thats all you can have, they are still better than a run of the mill stock smog head, or just a non performance stock head
      Nov 2004
      livonia mi.
      cool it's going in & yes it's the old comp 272
      Nov 2004
      In the black hole,Midwest US
      That's my cam
      Just thought I mention that I am already running that EXACT cam in a 68 nova. The car has a 4-speed and 3.08 gears, with a set of old double humps and about 10 to 1 comp. and it runs a low 13 sec. quarter. I ran another cam that was a little bigger and the motor did'nt seem to run as good or wrap up as fast. I LOVE THIS CAM it is great. Run it and you won't be sorry.
      1968 Chevy II Nova
      no go, no show
