      St Louis, MO
      Looking for engine weights.
      I'm looking for the complete weights of a couple engines.
      Olds 455
      LS1 alum block
      or a newer GM 2.0 ecotec.
      Trying to decide if swapping out the 455 for one of the other two would save me enough weight to justify it.
      It'll be in a 65 Corvair.
      Boston MA
      search function. It's one of the three or so topics that comes up on this board.
      1967 #s RS
      St Louis, MO
      Quote Originally Posted by wendell
      Thanks for the helpful information. I've never thought about that. The LS1 comes up often, but not the olds or Eco tec.
      SO far from googling I've found the avg weights
      http://www.241computers.com/ford/Con...s20-30-38.html
      Olds 455 620lbs
      Ecotech 307lbs http://www.theautochannel.com/news/2...07/035473.html
      The LS1 460-500 http://www.corvetteactioncenter.com/...06/ls1ls6.html
      So, I'll be best to go with the Ecotec to save a couple hundred pounds.
      i had read one of your corvair posts, i was thinking you should do a ecotech mid engine but didnt say it. those blocks are bulletproof, i heard of a ss s/c cobalt getting ran on a bigger pulley with a 75 or 100 shot of nitrous sprayed 10 bottles through it and never grenaded it in 10k miles.
      85 grand national-t66, supporting mods
      99 xtreme s10-daily slammed on flat black 20s, tons of body mods
      02 337 editon gti "1 of 1500"-audi tt drive train factory, recaros, bbs, votex body package"270hp 310 ft lb"
      79 trans am- pro touring/track/dd project
      St Louis, MO
      I was going to go with an Eco, but after calling a couple of mfg's it's going to cost a little over $1,000 just to get a trans adapter made. That's more than I'm willing to spend for an adapter.
      Aug 2001
      Connecticut
      is an ls1 that heavy? or is that the steel block versions? reason I ask is that an alum. head sbc with a steel block is around 450-460lbs; and my all aluminum sbc came in at 355lbs.
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
