Thread: SPAL question
01-10-2008 #1
SPAL question
I am just getting ready to install my SPAL fan-pwm, fan relay harness FRH, and water temperature switch # 25036979. I am using dual fans from a dodge , because of the clearance issues from the supercharger pulley. My first question is : Temperature range of the temp. switch from spal. It has been so long that I do not remember.
Second question: Can an autometer temp gauge be connected to the spal temp. sender, and operate properly ? If so, how would this be wired together ?
Thanks in advance for an help !
01-10-2008 #2I believe the temperature range for the Spal sensor is 32F degrees to 270-280. You can splice into the white temperature sensor wire with your Autometer gauge sender wire. The white is your variable voltage input, the black is ground.
[email protected]
01-11-2008 #3Thanks for the help clearing up my questions.
