      Oct 2006
      Trouble w/rally rim
      Had a full set of 15x8 chev rallys that my race tires have been mounted on. One of the rims has gone bad so I am on a search for a replacement. I always thought these were 4" BS but I measured the reamaining three the other day and they look to be 3 1/2" BS. I was given a brand new Wheel Vintiques "hot rod style" rim that I thought I could use but it turns out to be 4 1/2"BS. ARRGH, the saga continues...
      Robert
      May 2002
      Northern California
      do you need one or are you venting? put an add up in the wanted section. Also, where are you from?
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Feb 2007
      I will check the two ralleys that i have with slicks and will get back to you if the b/s is what you need
      Oct 2006
      Yes, I do indeed need one.
      Now I hope I'm measuring the backspacing correctly. I laid a straight edge on the flat part that the tire bead is against and then measured down to the mounting surface of the center.
      I'm in NorCal. Near Berkeley.
      Brownz thanks for checking/
      Robert
      May 2002
      Northern California
      All the ones I have are 5". make sure its a 15x8. doesn't sound right.
      San Diego, CA
      See this page on how to measure backspace and rim width:
      https://rsracing.com/tech-wheel.html
      Note that the rim width is not how wide the rim is, but rather from bead seat to bead seat. A lot of people mistake this measurement.
      Oct 2006
      According to the diagram on the website I'm measuring wrong. It says to lay a straight edge across the outer edge of the rim and measure down to the center. I always thought you measured from the flat part inside the lip(bead sealing surface). At any rate it just adds about a 1/4" to my measurements.
      http://im1.shutterfly.com/procserv/4...6108BcNW7ly0b8
      Measuring the other way I get about 4" on the stock rim and about 4 !/2" on the aftermarket.
      Robert
