Thread: proper ecm chip
01-02-2008 #1
- Oct 2007
- ridgefield ct
- 876
proper ecm chip
i'm wondering what chip would work best in my car. i have a 383, 9.7:1 d-dish pistons, xe274h-10 cam and vortec heads. i have the stock, computer controlled distributor with a 305ho chip in it. for best performance do i use a high performance 305, a standard 350, or a HP 350 chip? it works well so far but i of course want everything out of it that i can. the computer is hooked to a knock sensor, ECT sensor, MAP sensor and of course the dist. evrything else is disconnected and about to be removed.
thanks for your help.
01-14-2008 #2
- Aug 2005
- 198
If all it is really controlling is timing, I would think they would all have similar curves. If your still using the TBI, I would run the computer that matched the TB and have Affordablefuelinjection.com burn you a chip that can best suit your cam, eliminate unused sensors and match the demands of the better heads.
68 Chevelle SS396. Pro-touring in Progress
Pro-jected 396, TKO 600, 3.90'd 12 bolt, LS1 brakes.
01-14-2008 #3
- Oct 2007
- ridgefield ct
- 876
it's still carbed. people always talk about changing their weights and adjusting the vac advance on a traditional distributor so i figure the electronic one is a bit behind. especially on a curve intended for an emissions 305.
