    Thread: tko600 speedo
      NYC
      tko600 speedo
      what do you need to switch from manual to elec speedo
      May 2000
      http://www.sw-performance.com/products/SDRSpeed
      Hall Effect sendor.
      Used one on a 700R to electric gauge before.
      Welland, Canada
      When I switched from a muncie to a TKO the hal wouldn't work. On the passenger side of the trans is a plug in for the electric speedo. I'm using an Auto meter.
      I used a Calterm p/n08692 which I got from GMJim. I could not find any info on this p/n. Anyway on the box it says "GM multi use sensor plug"
      for GM 1985 to present plug for coolant temp, brake fluid,washer fluid.
      So I checked Rock auto and found this "STANDARD MOTOR PRODUCTS Part # TX3A" which looks like the right one to me, about $8.
      Dean
      69 Camaro 355-3.73 Moser Truetrac-TKO600-Hotchkis-DSE-QA1's-Baer's-17"Budnik's
      ST U/LCA's-GW Del-a-lum's-Lee p/s
      TuoCo, CA
      I got a kit from these guys. F'ing expensive though...
      http://unforgiven-chevelle.com/products
      Steve
      Check it Out Here
      The TKO already has the sensor in it. All you have to do is plug the mechanical speedo hole with the correct part and use the weatherpack connector that HuggrrrPT used and hook it up. No generator required.
