Results 1 to 20 of 22
- Jan 2007
- 97
63' Belair Wagon
So maybe not as exciting as some of the high-dollar builds on this site, but somewhat "pro-touring" nonetheless. For those of you not familiar with my project, it's a 63' Belair Wagon that I'm building as a family car (hopefully it'll be on the road by the time my wife & I have kids) that I can also take to the drag strip or go autocrossing with.
Engine: 396 SBC
Trans: 700R4 w/ Lokar shifter
Rear: 9", True-trac with 3.90's, 31 spline Axles, Moser center
Brakes: Hybrid C5/C6 setup from Kore3, 14" front, 13" rear
Rims: TTII's with gray centers (to be ordered)
Suspension: air ride Tech DA shockwaves up front & cool ride ride with SA shocks out back, all control arms are custom pieces out of chromoly.
Interior: About every factory option conceivable with no hint of anything aftermarket except the shifter.
The rear tires I ordered are BFG g-Force KDW TA's that are 285/30/20's. There wasn't much clearance and I don't want to do any extensive modifications, so the panhard rod had to be ditched in favor of a Watt's link. The height of the pivot isn't adjustable so I can't do anything about roll center, but it's a street car for Christ's sake. Everything is just tacked in place for now, but initial measurements showed that it'll keep the rearend perfectly centered for 10" of travel (I only have 8"). The back brace is stepped so that it can clear the rear shocks. A jig was made from the factory rear setup to get the brackets perfect. It was also converted to a factory 4-link since most 63's only had a 3-link w/ PHR setup. The upper arms were also relocated about 3/4" forward to clear the Watt's setup.
I'll post more pictures as I take them. Similar to 70cuda's setup I'll have an optima battery in the spare tire compartment with all of the air ride components.
Enjoy,
Eric
