    Thread: T56 into A-body
      Alta Loma,SoCal
      T56 into A-body
      Anyone know if trans tunnel modifications are needed when putting an LT1 t56 behind a gen1 SBC into a 64-65 GM A-body?
      Thanks.
      Phil
      1965 Buick Skylark
      Phil -
      I can tell you floor pan mods are req'd when installing one in a '66 A-body behind a big block. Basically the tunnel is too shallow and too narrow as I recall. DSE may be able to tell you better, they did mine for me.
      One thing I'd do different - - to remove/install the trans, I have to remove the adaptor plate from the trans (D&D T-56) to get the trans out of the car. The adaptor stays bolted to the bell housing. To access the top bolt between the trans and adaptor I had to cut an additional access hole in the floor pan to reach it. VERY tight squeeze. So make sure you keep trans servicing in mind when you're fabbing the tunnel.
      Bob
      Mooresville, NC
      '66 Chevelle SS (461, T-56)
      https://www.pro-touring.com/forum/vb...?do=view&g=274
      Southern California
      I had to cut a ton out of mine. I am running the T-56 behind a SBC. Bob is right, too narrow and to short. You will end up cutting about 2 inches back from the firewall. You will also have to make room in the floor pan for a selonid on the drivers side of the trans....lots of fitting, but it has been lots of fun too!
      May 2000
      You can fit them in 1st gen Camaros and 3rd gen Nova's with no probem, but they won't fit in these big Chevelles.
      I recently did the tunnel work on a '66 to get one to fit.
      Aug 2003
      Yes, bring the plasma cutter. Even the TKO requires a cut chop of the tunnel on these cars
