      Apr 2003
      Central Valley, CA
      TKO shifter swap
      Here's the deal...
      I'm going to be totally hacking out and modifying my transmission tunnel very soon, my car is so low now that the driveshaft taps the floor occasionally and I need to raise the tranny more to reduce my u-joint working angles.
      Right now I'm running an older TKO with a Forte's 16.75" location shifter to work with a stock console. When I re-do my floor I'm going to move my factory console or build my own console and want to move to the rearmost shifter location so I can run a more ergonomic and more "straight up" shift lever. The current 16.75" shifter location works great with the stock console but requires a fairly long "dogleg" shift lever which effectively results in longer shift throws.
      What's the best feeling / shortest throw shifter at the moment (newer style red Tremec, McLeod, Pro 5.0, Steeda Tri-Ax, or other?) and will it work with my older TKO if I move the socket on the shift rod back to the rearmost position? The socket inside the tranny is currently pinned on the more forward hole on the main shift rod to work with the 16.75" position. I'm assuming if I move it and re-pin it to the rearmost position I can install any 3550 / TKO shifter in the rearmost location.
      1969 Chevelle
