      SAN FRANCISCO BAY AREA
      Freshen' up a 6.0L
      Has anyone taken a LSx motor with several thousand miles, or in my case an undetirmined amount of miles, and freshened up the motor. What I mean by freshen up is rings, bearings, ball hone, and have all the machined surfaces cleaned.
      I figured I would go as far as to have the machine shop re assemble the short block, balance the rotating assebly along with the balancer and fly wheel. While the motor was being put together I would add a cam, ported oil pump, timing chain, and rod bolts.
      I ended up getting the motor for free so I wouldn't mind spending a few hundred bucks to make sure it was bullet proof and dependable.
      What do you think the machine work would run and am I waisting my time trying to freshen up a motor with some miles on it?
      BRIAN
      Henderson,NV
      Brian,
      Todd
      Henderson,NV
      Brian,
      Todd
      Henderson,NV
      Brian,
      It's impossible to answer that question because your engine is not torn apart. I would inspect the motor internally by pulling off the valve covers and oil pan to see how it was maintained and if the crank bearings look good. Pull the spark plugs and see if they were all burning even. If all looks good you could pull it apart and just freshen it up or run it as is.
      Todd
      Jackson Ms
      i would run it as is unless you know of a problem. I had 238,000 on myold 5.3l and it was still going strong when i sold it.
      Chris V
      SOLD
      Vancouver BC
      I rebuilt my '01 LQ4 about a year and a half ago. It was a low mile engine and I had it hot tanked, honed,new cam bearings installed and had the crank balanced. I rebuilt it myself with new pistons, all new bearings and gaskets, and upgraded everything else with performance aftermarket parts. The bearings and gaskets were quite expensive when compared to old sbc stuff. I think all the bearings and gaskets were almost $1000.00. My machine shop wanted $400.0 to put it all together but I did it myself as I like to get my hands dirty and I love engines.
      Make sure to upgrade the rod bolts, oil pump and timing chain while your in the bottom end. I used ARP stuff everywhere.
      Mike Kirkwood
      81 Z28 LQ4, Baer brakes, Global West everywhere.
      http://s231.photobucket.com/albums/ee283/zedzag/
      Nov 2007
      Rolling Meadows, IL
      if nothing is broken and you just want to re ring it and bearings and have the balance check and so forth, its cheap insurance and I would do it. nothing worse than sticking a motor in a car and then having a problem shortly after that..
      Sean Falls-Sales/Business Manager
      1998 Z28-D1SC at 13 PSI/FMIC/Th400/12 bolt/Cage/Full suspension/Fuel system/347" LS1, custom paint and body work!
      [email protected] 1.39 sixty http://good-times.webshots.com/photo...ost=good-times
      2003 WRX-dropped on 18's, up pipe, turbo back, Cobb stage 2 tuning, etc-the corner carver!
      2006 Artic Cat F7-the winter toy!
