    Results 1 to 16 of 16
      Monroe,WA
      Caddilac LQ9 question
      I found a 2004 6.0L lq9 cadillac escalade motor for sale on craigslist for a reasonable price, but I cant seem to find any info on the throttle type. Is it drive by wire or cable actuated?
      Jul 2007
      It's a drive by wire...make sure to get the pedal and module.
      Jan 2007
      Vacaville, CA (NorCal)
      or change the TB to a cable type
      2011 GMC Yukon XL - 24's, buncha Escalade parts
      1972 Chevy C10 - Dropped & Shaved
      1970 Chevelle SS396 - currently in Body-off Resto
      1970 Chevelle - (LSx TT 4x4/SUV Chassis Project)
      Southern NJ
      My LQ9 Silverado was drive-by-wire.
      Matt
      1965 Pontiac GTO – Spotts 421 Tripower | TKO600 | 3.90s | Vintage AC | Baers | Hotchkis/SPC/BMR Suspension | Intro Vistas | BFG KDW Redlines | 06 GTO Seats
      Monroe,WA
      Any problems with converting from D.B.W to throttle cable? (wiring,ecm,etc...) Thanks for everybodys help
      What kind of Tranny are you gunna put behind this bad boy?
      Dunwoody, GA
      No problems with converting to cable from DBW. Just be sure to have the PCM tuned accordingly. If you're having someone else do the harness, make sure they know of the change as well.
      Trey
      ~ Jon Hammond
      Eastern Virginia
      Quote Originally Posted by PT Goat
      What year was your Silverado that had the LQ9?
      Scot
      86 Monte SS
      California
      Pretty sure Silverado's never came with LQ9's.
      Matt
      Flo-rida
      Quote Originally Posted by DarkoNova
      Matt
      The 03-05 Silverado SS did, the LQ9 is just the High output vortec 6.0L, and what ever had the vortec max option came with the LQ9 motor.
      1993 Camaro Z28
      2001 Camaro Z28
      1969 Camaro
      Eastern Virginia
      Ah I see said the blind man. Mine has the LQ4, what is the difference between the two?
      Scot
      86 Monte SS
      Southern NJ
      Quote Originally Posted by Samckitt
      It has been covered above, but since you asked I had an '03 Silverado SS. As others have noted, the LQ9 came in the SS and eventually the Vortec Max. It was premium only (higher compression), while the LQ4 was okay with 87. Pretty sure the HP was 345 vs. 300.
      Matt
      Eastern Virginia
      Are the heads, cam same/different?
      Scot
      86 Monte SS
      mo
      same heads different cam I believe, My Vortec max Silverado has the LQ9 in it
      Thall shall fear no amount of boost, For thy bottle is with me.......
      Dunwoody, GA
      pistons and rods where different in the 9's. That's how they increased compression versus using a smaller cc head. The rods are just stronger but the same length between the two.
      Trey
      ~ Jon Hammond
      Monroe,WA
      Quote Originally Posted by cDuck28Z
      The all mighty t56....if I can find one!
