      Melbourne, FL
      67 F-body dash connector
      I hope I describe what I'm looking for correctly. I'm looking for a plug that will connect to the connector that connects to my dash gauge cluster. I don't need any type of fancy harness. Just a plug w/wo pigtails, prefferably with, that I can make a custom harness for my project. I am using 5" tach and speedo in my original dash housing. But I want a clean method to connect to all of the stock circuits that originally went to the dash gauge cluster. Even though I am using gauges for water, oil, etc... I want to retain some of the stock warning lights, turn signal, high beam, ... without just splicing into the harness behind the connector. I probably could fashion a few seperate connectors by cutting the existing connector off and adding a few plugs. But I want to keep the current harness stock and make a new harness.
      I hope I made enough sense in trying to describe what I want to do. Any help/suggestions would be appreciated.
      Sep 2003
      Tampa, Fl
      Brian
      '68 Chevy Stepside-Fatman, HTH, 8.8, Baer, Hydratech, LS1/T56. I know it's a truck but you gotta start somewhere and I need the challenge.
