Thread: anyone using EVANS NPG(+)
12-10-2007 #1
- Oct 2007
- ridgefield ct
- 876
how's it working for you? did you need any modifications?
i'm using NPG+ in my monte with a 195' stat and an old stock radiator and my car seems to run at 180!
12-10-2007 #2
Starting The Transformation
- Aug 2004
- 210
I used it years ago in my stroker Hayabusa. 1500cc and 13.5:1 put a serious load on the cooling system here in the desert (especially in the summer). It did not run cooler, but it would not overheat either. I attribute that to the NPG's ability to resist boiling at localized hot spots where a water based coolant would have boiled at that spot.
I still have 4 or 5 gallons of the stuff onopened, and plan to put it to use when my new boosted street motor for the GTO is ready to go this spring. Evans is a great company to work with. They made me a custom Pontiac reverse rotation water pump which greatly simplified setting up the accessory and blower drives.
12-14-2007 #3
- Mar 2005
- 467
I'm using it in a new LS7, haven't had much experience with the engine yet since it is just being completed. I'm running NPG with a 3 core Fluidyne HP radiator and Spal variable controller. Since the motor was new it was an easy add.
