      Nov 2007
      roll bar questions
      Im in the middle of a 69 camaro build. Hoping for a low 10 sec runner. NHRA states that if ur firewall and floor are stock you only need an 8pt roll bar. Im replacing my floor pan b/c of rust and smoothing the firewall. Does this violate their "stock" definition? Assuming it doesn't does anybody make an 8pt bar with contoured bars that go from the main hoop to thru the rear deck and into the trunk? Instead of going straight from the hoop to the trunk.. can it follow the roof line and then drop down when reaching the rear window?
      Nov 2007
      here is a pic of what I want
      https://www.pro-touring.com/featured...S/Roll_Bar.jpg
      also if I make the bar in the middle of the main hoop and the bars coming down from the main hoop to my feet detachable does that violate NHRA?
      Merritt Island,FL
      What your discribing does not violate the rules.
      What you need are custom bent bars.
      That is how I bend mine for guys that want to keep the rear seat.
      Brian
      Check out my web site.
      Dec 2007
      Simi Valley, CA
      I can bend up the roll bar for you. it will meet all NHRA specs. 4130 tig high quality...
      Nick
