    Results 1 to 20 of 43
      NYC
      Where does everyone have there MSD boxes mounted?
      Hi was wanting to get some ideas on where to mount my MSD box,where do you guys have them on your cars?
      George
      `67 Buick GS 400 Hdtp,494ci Stage 2 BBB,5-speed TKO-600,"The Black Widow"
      Nov 2000
      O-town
      above the heater in the engine bay, Nova
      CT
      I have mine mounted under the cowl on the passenger side.
      Its bolted upside-down with the wires popping out of the firewall next to the dist.
      Phoenix,Arizona
      Quote Originally Posted by sunkistcamaro
      same here (72 Nova)
      Brian
      -1972 Nova
      -1968 Camaro
      -1990 Iroc Camaro
      Feb 2004
      Paris, Illinois
      I made a plate and mounted it to the bottom of the Vintage Air fan shroud.
      In the car:
      Michael
      1969 Camaro
      CamaroHeaven.org
      fQuick Garage: http://www.fquick.com/Overkill
      Florida
      Above the heater box on firewall in engine bay, 2nd gen Firebird
      Same on 2nd gen Camaro
      Same on 1st gen Camaro
      On firewall under dash, 67 Nova
      Oct 2006
      Pittsburgh Pa.
      Engine bay firewall, they are noisy.
      Feb 2002
      Springfield, MO
      Mine is under the K&N Cone filter on top of the inner fender "flat" area, between the fender and the core support, behind the grille edge. Descriptive enough? LOL!
      Jimmy
      69 Camaro Twin Turbo'd
      58 Nomad 348 Baby Rat
      Fontana, CA
      Backside of the Drivers headlight on the core support.
      Nick R.
      Jul 2007
      Tracy, CA.
      Quote Originally Posted by 6'9"Witha69
      +1, me too!
      Steve Martin
      67 Camaro RS
      66 Chevelle
      Nov 2007
      Metro-Detroit, MI
      in my 2000 Dakota R/T it's mounted under the passenger seat.
      Mar 2002
      Redwood City, CA
      On my '77 Camaro, it stated out on the passenger side fenderwell. It will now reside on the firewall above where the heater box should be. Then again, I may move it under the dash, or under the fender. I'm not totally decided anymore.
      Allen Ortega
      NYC
      No one got one mounted in the glovebox?keep `em comin boys,lol.
      George
      CHICAGO SUBURBS
      I've done one mounted in the glove box. It also has a PC cooling fan mounted in there to keep some airflow. My car is mounted the firewall above the heater.
      Nov 2004
      The original home of Nickey Chevrolet
      msd box mount
      Back side of fire wall (interior) above the trans tunnel. Short wire to distributor, easy access and out of sight.
      May 2003
      St. Charles, Mo
      MSD box
      I have my coil and MSD box mounted under the dash. The coil is above the steering column and the box is above the gas pedal.
      Sep 2007
      Thehoodstock,GA
      Is Mr. October on this forum?
      This is where he mounts his:
      Melbourne, FL
      Quote Originally Posted by no bags
      I'll second this one. I welded some bolts to the pan so I can mount my coil and box on a single plate. Then bolted the plate to the floor pan with shock absobers between the plate and the floor pan. Up and out of sight. Also being a convert there is plenty of air flow in the car to keep it cool.
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Jun 2002
      Oregon
      Mine is mounted to the side of the DSE VA bracket under the dash...just like they did on ALUMIN8R. http://www.detroitspeed.com/projectp...ms-096_pic.htm
      Tony
      Massachusetts
      upside down on pass. wheel well so the rev limiter chip is easy
      to get at
      CAN YOU BUILD PROTOUR ON A BUDGET?! NOT!
      Time isn't something you have!
      It's something you make!
