Results 1 to 10 of 10
Thread: Acell DFI ignition set up help
12-07-2007 #1
- Feb 2005
- Damascus,MD
- 57
I need some help in setting the ignition settings in Calmap. I've tried calling the tech line but was unable to get through. Hopefully someone here can help.
I have a Gen 7 system. I have no spark at plugs. I'm using an HEI distributor with no module and an MSD 6AL box. Pick up coil is connected to the crank- and crank+[Pins 'C' and 'D']. White wire is connected to points-est pin "H". I have selected universal IPU in the ignition setup in the software as I was instucted by Accel the one time I did get through. No spark at plugs. I have the distibutor out of the engine so I can spin it by hand. I have tried all the options in the ignition configuration and none work. I have tested the pick up coil and the MSD box and both work. I even sent the computer back to Accel to be checked out. They say it tested out fine. I'm at my wits end
Thanks for any help.
The Dr.'s 1st law of auto repair: When the need arises,any tool or object closest to you becomes a hammer.
12-07-2007 #2
- Sep 2004
- Kettering, OH
- 537
Can you take the crank coil out and set it up in batch mode to see if that's the problem?
12-07-2007 #3
- Feb 2005
- Damascus,MD
- 57
I have it set up for staggered batch now. By take out the crank coil do you mean run in fuel only mode? I know the pick up coil is good as I can unplug it from the computer and hook it directly to the MSD and I have spark. It's like the computer isn't reading the pick up coil.
12-07-2007 #4with the hei and 6al i dont believe that you can control timing in that setup. i may be wrong but unless its a 7pin hei you will be in fuel only mode. someone correct me if i am wrong.
12-11-2007 #5
- Nov 2004
- Colorado
- 1,260
