      Linwood,NC
      Custom Aluminum Fuel injection Gas Tank
      I have swapped a LS2 motor in my 69 camaro and when looking for a tank I found a guy locally that built one for me. I thought I would share the info. It is a custom built tank built to factory dimensions with a sump added for the pump to sit in. It is fully baffled and fit in the stock location using the stock straps. I ordered the Tanks Inc walbro pump and a sending unit for the gauge and took them to him. I couldn't be happier with his work and the look and fit of the tank. A tank contoured like mine with all the angles cost around $500. He will need your stock tank or a detailed drawing with measurments along with the pump you want to use or he can supply a GM pump. I will add a few pictures of my tank.His main business is building aluminum radiators. Contact info: Tapp Inc. Located in Sophia, NC #336-861-9284 http://s271.photobucket.com/albums/jj125/nc69rs/
      Flo-rida
      Holy crap that thing is titties!!!!!
      1993 Camaro Z28
      2001 Camaro Z28
      1969 Camaro
      Jacksonville, FL
      Just curious, are you are going to have enough clearance between the sending unit and the trunk pan when it is installed?
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Linwood,NC
      Luckily it cleared ok! But I would have it recessed if I did it again.
      Chicago
      now that's a nice gas tank
      marty-mj
      Sep 2001
      Accord, NY
      Nice! For other 69's I wonder if he had all the info needed. Very nice alternative. Hmm.
      68 camaro - SOLD
      Dec 2007
      I'm going to call him and see what he would charge me to build one for my '63 Vette.
