      Feb 2006
      Elk Ridge, Utah
      SSBC master cyl Q
      Anyone know what master cyl I can use with this SSBC brake kit? car is a 69 Maro w AFX spindals Sovitskie uppers
      http://www.ssbrakes.com/products/det...967%20-%201969)
      Why dont I call them?
      They are complete baffoons.
      They didnt ship the rotors and then sent them ground 2 and a half weeks later..
      Upon install they neglected to install the helicoils into the brake caliper feed holes.. They also didn fit right I had to send the caliper mounting braketts out to take .080 off them so the outter pads werent SLAMMED against the rotors nor the rotors rubbing the inside of the calipers..
      all total 50 + days to get system and car still on my rack tying it up...
      would I buy anything from them ever again???? I THINK NOT
      69 Camaro
      W/D sub, Wilwood 13" brakes Bozeforged wheels 18X10 & 18X12,
      Lateral dynamics 3 link ( custom setup ) Dana 60
      lsX Twin Turbo, soon to come
      Viper T56 in place (Yay)
      Bought a running driving car so I can enjoy it before Im dead
      LD 3 Link Installed into ^^^^^ (Yay)
      Oregon
      From the specs listed for that front caliper, they have the same size caliper pistons and rotor diameter as a 98-02 LS1 F-body. Based on that I would say you should be in the neighborhood of 7/8 to 15/16 for a manual setup, 1" for a vacuum boost setup, and 1-1/8" to 1-1/4" for a hydroboost setup depending on which unit you use (and potentially smaller if you go with a Mustang unit). It could help to know what you're running for rear brakes.
      Sorry to hear about your "after sale" customer service experience with SSBC...but if it's any consolation, I don't think that you are alone. You must be running small wheels or something, otherwise you would have been money and performance ahead just to throw some C6 2-piston calipers and 12.8" rotors on there and call it a day.
      It's what I does.
