Results 21 to 40 of 40
12-17-2007 #21
New to Pro-Touring
- Dec 2007
- E. WA. State
- 19
Matty, I am building my own 3 link, was working on the crossmeber to mount the upper link tonight before I signed up to this site. I can't give you all the technical ifo, you may be asking, but my friend that is explaining as I build, (lol) does understand, and I would be willing to ask and tell you anything you need to know to build your own
12-17-2007 #22
New to Pro-Touring
- Dec 2007
- E. WA. State
- 19
also, I am using my stock leaf spring front mounting points for my lower links, 9" ford rearend, DSE minitubs, DSE Sub Frame connectors, Not sure on my coilovers, just yet, I will buy Heim Joints and rods, but I will fabricate most of everything else. (1971 Nova)
12-17-2007 #23
- Nov 2007
- 266
id like to see some pics if you wanna put em up. You using the stock rails or did you go ahead and put in new rails and tub it? I know our procedures will be way different but luckily I think mine will be the easier way.
12-18-2007 #24Are you offsetting the odd link? If you offset it correctly, you can dynamically cancel the effect of driveshaft torque on rear wheel loading. In other words, your rear tires can be equally loaded during launch with any value of driveshaft torque.
Originally Posted by Exhausted
See Page 18 of my site for setup information. Check out Pages 4, 5, and 6 for a method to verify your setup.
http://home.earthlink.net/~whshope
12-18-2007 #25
- Apr 2007
- 175
what is more advantageous... parallel lower links or triangulated???
12-18-2007 #26
- Nov 2007
- 266
i believe that angled lower bars are better, why and how much I dunno but I read its better
12-18-2007 #27As usual, there's no correct answer. It depends on your application. Angulation of trailing links (either top or bottom) is usually done to avoid the need for a Panhard rod to take lateral loads while cornering. It's very difficult, however, to provide convenient adjustment with triangulated links. In other words, you're usually stuck with the percent anti-squat of the original setup. With links that are parallel to the long axis of the car, you need a Panhard, but, on the other hand, it's relatively easy to provide adjustment.
Originally Posted by baggins
And, of course, there's the matter of packaging. With any given car, one setup is going to be easier to install than the other.
So, it comes down to what you want to do with the car. If it's only going to see street duty, there's really no reason for tinkering with the percent anti-squat and the triangulated setup will be quite adequate. But, if it's essentially a dragstrip car, you probably will appreciate the adjustment and you'll go with the parallel arrangement.
12-18-2007 #28
New to Pro-Touring
- Dec 2007
- E. WA. State
- 19
In reference to BillyShope's question, My upper link will be centered give or take an inch or two. I'm a drag racer at heart, I know a 4 link, would be better, but My car will very seldom see the track, It's just a car to cruise short distances, I plan on using mid 80's camaro rear bucket seats, mainly for looks not for function. Another friend of mine is building a 3 link, it's almost done, with the upper link, set about 4 inches toward the center from the right lower link. But it is mainly a drag car, maybe burgers on Sunday afternoon. I'll take a look at your sitght, thanks for the info.
12-18-2007 #29
New to Pro-Touring
- Dec 2007
- E. WA. State
- 19
Mattyb, I thought long and hard about mini tubs apposed to gutting the car, building new rails, and buying stamped tubs from jegs or summit, the mini's I think are over priced, but hey that guy needs to make a living to. They look great. I am not gonna go real wide for my rear wheels, thinking about 17x9.5 maybe 10's, I have 16x8 Torque Thrust 2's with a 5-1/4" back spacing, front and rear, on the car now. So, keeping the stock frame rails, going with mini tubs.
12-19-2007 #30
