    Results 1 to 12 of 12
      Hightstown, NJ
      Northern Boys - Winter Maintenance
      I realize this question maybe a little elementry for most here but I've heard various answers from mechanic friends of mine.
      During the winter, how often do you guys start your cars?
      New Jersey
      What are you worried will happen if you don't start it for 3 months?
      Just pull the batt out and place on a piece of wood.
      Camaro Convertible Build Pics - http://s447.photobucket.com/albums/qq198/rob07002/
      www.musclerides.com
      Rob Stevens
      Hightstown, NJ
      Won't the cylinder walls rust as well as all the seals dry out.
      Jun 2002
      Long Island, NY
      Fuel Stabilizer is probably a good idea as well; the shelf-life of gas is said to be about six weeks.
      Also, condensation is generally the cause of engine rust, especially in the northern climates where it's 0* in the winter and 90 in summer. When starting your car, be sure to let it idle to full temperature and then run for a while so as to burn off any condensation. The worst thing to do is run it for only a few minutes; in that situation, it's better to not start it at all.
      New Jersey
      Nah, not for that little amount of time. As long you don't have water leaking into the cylinder slim chance you'll have much if any rust.
      The cyl walls have a very thin coating of oil from use, and the seals are fine for that duration.
      I've seen motors taken our of storage after years and fired up and raced with no problems. All we did was back the valve springs off and stuff a rag down the carb or pull the carb and duct tape the opening.
      I've know guys to pour tranny fluid down the carb (when running)when they were storing something for a LONG time. Have to be careful when doing that though, - hydrolock.
      And yes, what Ralph said! fuel stabilizer
      www.musclerides.com
      Rob Stevens
      Aug 2001
      Connecticut
      Double dose of fuel stabilizer, unhook the battery (keeping it in a warmer place if your garage gets real cold, and/or battery tender), back off the valves (for solid lifter or mech roller motors); lots of mouse killer in the interior and trunk, and steel wool in the exhaust pipes. My garage is very clean and I've still found mice in the winter. Years ago I lost a headliner to one, so ever since, lots of Decon and traps.
      If it's a shorter stay or you don't like backing off your valves, turn the motor over 1 to 1-1/4 rev every week or two just to keep the springs from taking a set or getting weak.
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Chesapeake, VA
      You can squirt a little motor oil through each spark plug hole then turn the motor once by hand to make sure the rings spread it all up and down the bore. One caution, though. I know someone who thought he would take a short cut and use WD40 instead. Next spring all the pistons had white oxidation on the skirts and were stuck so tight in the bores they had to be knocked out with a hammer and a block of wood.
      I have been winter storing for 10 years in the UP of Michigan and I add stabilizer and unhook the battery cables, place the decon or mothballs and thats it. 5 months in storage. No issues with battery or anything else...
      Fontana, CA
      Why would you need to store a car for the winter? Oh nevermind, cold, snow and ice. Got it. Don't have that round here.
      I have always heard stabilizer, valves, battery cables and rat poison. The steel wool in the exhaust pipes is a good idea to keep the lil' bastids outta the exhaust.
      Nick R.
      RI
      I just put mine in the garage at work. It stays between 50 and 60 all winter. I turn the motor over now and then and filled the tank 3/4 of the way. I also changed the oil befor I stored it. I see the car everyday and I'm working on it trough the winter. I try to move the tires so I don't get flat spots, which is easy since I have to jack it up anyway. I also keep the battery disconnected
      Frank M
      1970 lemans sport
      2005 srt-10 ram
      http://www.youtube.com/watch?v=SER1gBLn2N0
      Welland, Canada
      All I do for the 4-5 months is disconnect the battery, change oil, fill with gas, open windows a crack and put a cover on.
      I store in a garage with no heat and don't bother to start it at all. If you can take it for a long enough ride to get temps up then your alright, otherwise just starting and letting idle a bit is bad news.
      Dean
      69 Camaro 355-3.73 Moser Truetrac-TKO600-Hotchkis-DSE-QA1's-Baer's-17"Budnik's
      ST U/LCA's-GW Del-a-lum's-Lee p/s
      Chesapeake, VA
      If you do NOTHING else be sure to put stabilizer in the gas. Last winter I tried to run my snowthrower on the last gas left in the can from the mowing season. Two months old and all the good was gone.
