      Oct 2007
      orange county, california
      Valve Springs!!!!!!!!
      so can anyone tell me the specs on stock LT1 (95 trans am) valve springs
      I was gonna order a set of Beehive 918s but every place i looked is sold out for the next two weeks. So now im looking into the 915s.
      I know they can fit on a stock head with no machining needed, but i want to know if i can use my stock retainers and all that other stuff on the springs with them, or do i need to replace all that too?
      i hope not cus im on a tight budget... any help would be appreciated soooo much thanks guys!
      heres the specs for the 915s, my new springs
      Specs
      OD: Top 1.055" Bottom 1.290"
      ID: Top .650" Bottom .885"
      Seat Pressure: 105 lbs @ 1.800''
      Open Pressure: 293 lbs @ 1.200''
      Coil Bind: 1.100"
      Spring Rate: 313 lbs/in
      "What is each day but a series of conflicts between the easy way and the right way?"
      69 camaro, daytona blue. LS376-495 (Hotcam LS3), TR-6060 6-speed
      Tubular control arms with coilovers
      Sep 2002
      San Jose, CA
      You need to get matching retainers... the beehive springs use a dedicated retainer.
      You might also look at the Isky 235-D with the 707 STA retainer it will fit the stock pocket and take .550 lift
      Just call me Brett
