    Results 1 to 9 of 9
      10 bolt identification
      Over the winter, with xmas gifts I hope to upgrade to a posi. So I have started to try and identify the rearend in my 68 camaro. It should be a 12 bolt but a previous owner swapped in a 10 bolt. From looking at pictures, I think it may be a 7.5" 10 bolt. I know the best way is to pull the cover, but they have not salted in Pittsburgh yet, so I am still driving the car. Just trying to get an idea.
      What do you guys think?
      JEFF
      1968 Camaro RS/SS - "BLUE"
      www.fquick.com/jmd68rsss
      May 2002
      Northern California
      from that angle looks like a standard 8.2 10. Not sure if they made a 7.5 that would fit a 1st gen f-body. Maybe big gear head will chime in.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Thanks Mr Quick. I would probably keep a 8.2.
      JEFF
      Hildebran, NC
      I don't think any stock model of the 7.5" would fit in a first gen.
      It is probably a 8.2" or 8.5" ten bolt.
      The easiest way to id a 8.2" or 8.5" ten bolt is the pinion nut.
      The 8.2" uses a 1-1/8" socket on the pinion nut.
      The 8.5" uses a 1-1/4" socket on the pinion nut.
      Hope this helps.
      May 2002
      Northern California
      Quote Originally Posted by rchaskin
      easier way for 8.5 is to look at the bottom of the center housing...more material right below cover and look for the dimple in the cover.
      Northwestern NJ
      That's definitely not an 8.5" I can't see enough to positively ID it, but it sure looks like it may be a BP 8.2".
      Tommy
      Tommy Souren
      "The older I get, the faster I was."
      Grandma's 20k mile '80 Malibu Classic, in-progress factory style LS6 454, Legend LGT 700 5 speed, 9" 3.70 posi, Global West suspension, 12"/11" discs.
      Thanks for the replies. I am going to try and get a wrench on the pinion nut. May get a better picture.
      Is a BP 8.2 original to camaro's?
      JEFF
      RI
      Does look like a bop 8.2 rear. Does the cover have a cut on each side of the cover like a half circle?
      Frank M
      1970 lemans sport
      2005 srt-10 ram
      http://www.youtube.com/watch?v=SER1gBLn2N0
      I finally go under the car and took the cover off. It is a 7.5/7.625 10 bolt out of ???
      Needs replaced.
      JEFF
