Thread: Steeroids Issue, need some help.
11-28-2007 #1
Working on this 69 Camaro and it has a Steeroids steering rack into it. I am putting a flaming river Steering column into it. The column is a 3/4" DD shaft on it. The shaft coming off of the rack is something really weird, they claim it's a 3/4DD shaft but when I compare a 3/4DD u joint to it, it's shorter then the 3/4DD shaft but it's wider...........if that makes sense............
Any idea what it would be ?
Thoughts ?Tim Baillie
Owner / Publisher
The Hot Rodder Journal
Your Hot Rod Lifestyle Magazine
www.hotrodderjournal.com
12-04-2007 #2
Starting The Transformation
- Apr 2007
- Surprise, Az
- 196
not sure about the column but on my car it has a lumina steering rack ( which is what steeroids uses) and it had a 3/4" dd on it. on the column side they made a bracket that has two holes to line up where the coupler goes and this has a 3/4dd as well...
sorry caint help you out more on the column side
