      Annapolis, MD
      Moser 12 bolt question
      Hi, I just bought a beautiful brand new Moser 12 bolt with multi leaf perches, I am goint to install this on my 67 Camaro that had mono-leafs. I just bought the Global West dearched multi leaf springs with del-a-lum bushings and I have polyurethane multi leaf pads. Now for the question, can I use my stock lower leaf spring plates/shock mounts with the multi leaf upper mounts and multi leaf springs? If not where can I get correct lower leaf mounting plates/shock mounts? Thanks in advance for the help.
      connecticut
      the lower plates should be just flat ,so they are the same i believe. should work fine
