    Thread: Need some help
      Need some help
      I have a 67 camaro with a BBC, tko 600, stock front springs, DSE tubs and 1.5" drop springs in the rear. the car seems to sit about .5-.75 inch lower on the drivers side. i cant seem to find the exact spot but any ideas or suggestions of where to look. its enough to see and bugs me. thanks
      Before I started changing parts I would go to your local body shop and get some measurements with the car on a frame rack..this would set a base line and tell you if your problem was with the bolt on parts or with the frame..body..etc....they can set a car up on the rack in less than an hour and I wouldn't see it costing that much
