    Page 2 of 2 FirstFirst 1 2
    Results 21 to 31 of 31
    Thread: heater options
    1. #21
      Jan 2002
      Crockett, Texas
      Yep!
      Nice work, makes mine look like a hack job!
      It will give me something to do this winter.
      Don 67 Camaro RS/SS Texas
    2. #22
      Snohomish,Wa.
      Quote Originally Posted by TonyL
      Any corvair that runs headers has no heat. Same for a vw. So we have been dealing with this problem for quite some time. The best solution at the time seems to be:
      something like this coupled with heated seats or seat covers.
      remember that watts divided by the voltage of your system = the amperage draw. So a 300 watt heater is roughly a 25 amps. The unit pictured is small enough to hide under a dash, and can be modded with ductwork to actually defrost your windows, but provides little heat unless you're going to be in the car for over 30 minutes.
      Im still tempted to wrap one of my headers with copper tubing and pump water through it, back to vintage air's setup. I bet I could figure something out.
      Your idea about wrapping your header with copper pipe is great! I have a friend who owns a cabin in the Cascade mtns up here who has a wired fired hot tub outside. The tub is heated by a submurged aluminum box that vents out the top thru some 6" ductwork. Anyhow, in the wintertime it takes over three hours to heat the water from 38 degrees up to 102+. He wrapped the duct with about 75 feet of soft copper pipe(3/8" i think). with a small electric pump circulating the tub water thru the copper while the fire is burning, The heat-up time dropped by about an hour.
      I know this isnt even related to this topic, but this post reminded me of that. I am am certain that you can make it work. Just make sure you have a way to purge all of the air out of the lines, otherwise it may not heat up. Good luck!
      Roger
    3. #23
      west michigan
      I have been looking for something like this for so long. I shaved my firewall and didn't want the cost of a full air conditioning system but still want defrost. this is perfect.
    4. #24
      Jun 2006
      NW burbs IL
      Quote Originally Posted by ZZ430
      Yep!
      Not at all, I do notice the differences with the cable operated vs. the vaccum operated change the decision of how it can be mounted. With the manual units tube routing I was able to position the flapper door to open toward the driver. With the 90* tubing adapters it was a pain in the butt getting it mounted in a position to allow it. I suppose I could have moved it over to the left more and kept everything in the cabin, but I did have worries about to much heat near the PCM which I mounted on top of the trans tunnel under the dash.
      Matt
      Matt
    5. #25
      Mountain View, CA
      Matt,
      Any further info about this now that you've lived with it for a while?
      True T.
      My blog
    6. #26
      Jun 2006
      NW burbs IL
      True,
      I have only needed it twice. It blows light heat when stopped and cold air when moving. I have been to busy this summer to look into it. I think if I restrict the fluid to the heater core that may help. Otherwise I'm at a loss.
      Matt
    7. #27
      Mountain View, CA
      inetersting
      tis the season for figuring out your heater function
      True T.
      My blog
    8. #28
      Dec 2007
      Lombard, IL
      Tony, your link to the electric heater no longer works, but that's understandable, it's a year old.
      I've been driving my 56 chevy (most summers, when it's together) since 1985 and never had a heater. There have been some chilly spring and fall nights, but no big deal.
      Many times I've been caught in the rain and really needed a defroster. A little heat flowing out of the defroster vents would be great. My firewall is smooth and I don't want to add the heater hoses.
      I was thinking a small 20 amp electric heat source would be better than nothing.
      I could probably mount something like this http://www.sportsimportsltd.com/12vo300wadut.html
      on the inlet of my defroster vents. But I'd have to tear it open because I'd want to control the funtions with my dash controls.
      I'v done abunch of searching (for a small amp draw heater) it's either that or something like this http://www.sportsimportsltd.com/12allsehewic.html.
      I've searched around the web and these two types are about all I can find. whatever I do will be mounted in the inlet of the defroster vent and hard wired in.
      Any other suggestions?
      I've been lurking around this site a LONG time.
      Thanks for a great site!
      Dan
    9. #29
      Mountain View, CA
      Quote Originally Posted by Bow Tie 67 View Post
      I welded in a quick bracket to mount the VA heater and routed the hoses through the cowl vent area for a smooth firewall.
      Here is the bracket I welded in under the pass foot area to mount the unit without having bolts through the firewall.
      The hose exit and cover plate I made.
      And the clean firewall with all the lines hidden behind the fender
      Matt, your photos are dead. Any chance I could get you to email those photos to me?
      True T.
      My blog
    10. #30
      Jun 2006
      NW burbs IL
      here is a link to one, I should have more at home.
      http://good-times.webshots.com/photo...65608932BKChyx
      Matt
    11. #31
      Mountain View, CA
      Can't save the photo, can you email it to me?
      honukait at hotmail dot com
      True T.
      My blog
