    Results 1 to 11 of 11
      Wichita, KS
      What Should Fuel Pressure Be Set At ??
      I have a Big Block 396 with a Holley 650 Double Pumper Mechanical Secondaries. I am running a Holley Mechanical fuel pump straight to the carb. The pressure gauge on the fuel log reads 9psi. Is this too much pressure? Should I put a regulator on and set it around 6psi?
      May 2002
      Northern California
      Should be fine up to 11 psi. After that you'd risk over powering the needle pressure. 6-8 psi is where I keep mine
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Aug 2003
      I like 6 3/4 to 7 myself, As Vince mentioned your pushing the needle if you go much higher, and 7LBS should flow plenty even in drag racing situations.
      Jul 2007
      Tracy, CA.
      I run at 7psi!
      Aug 2006
      Taunton, Ma.
      Holley recommends no more than 5-7 psi of fuel pressure at idle for all of their 4150 series carburetors. They also require a minimum of 4 psi at WOT.
      John
      "There are no stupid questions, but there are a lot of inquisitive idiots!"
      NH
      9 psi is way too much
      7 max
      Feb 2007
      The base setting for a Holley is 6.5psi. No way run it at 11 or even 9 or you will have fuel coming out the vent tubes. If the guage say this and your not having problems it's reading wrong.
      El Dorado Hills, CA
      Mine's @ 7 too, I would get a regulator and drop it down to 7.
      Brad
      68 Camaro - Procharged LQ4 coming - Currie 9" narrowed, bagged, lays frame, BMW projector HID's LED tails, 18"s, lexus center console, seat warmers, A/C... Mini-tubbing in progress!!
      07 BMW 750li -loaded
      i run 6 psi with no trouble on the same carb as you . anymore isnt nessasary .
      do you rember what holley pump your running like the part number and also what type of gauge liquid filled or not?
      i tend to try and not buy new parts like a regulator unless i need it my holley pump pushes 6 psi all the time on the street or the track no reg
      josh
      Belle Plaine, MN
      6.5 - 7 psi is good. I've never heard of a needle/seat that could handle 11 psi!
      ~S~
      Scott Parkhurst
