      Nov 2007
      73 Nova Guldstrand Mod Questions
      I tried a search for 73 Nova Guldstrand Mod and I came up empty. I've been spending hours on this site and I'm a little confused
      Is the Guldstrand Mod template for 67-69 Camaro the correct one to use for 73 nova with stock A-arms?
      I am looking at the link from Pozziracing.com
      http://www.pozziracing.com/first_gen_suspension_geome.htm#Re-located%20upper%20mount
      Thanks.
      Dan
      Sep 2002
      San Jose, CA
      That is the correct template
      Just call me Brett
      Flo-rida
      How would i print that out to exact size needed? Ive been trying to do this but couldnt find the template for it.
      1993 Camaro Z28
      2001 Camaro Z28
      1969 Camaro
      Central CA USA
      Print out the template on my web page, it's a .jpg image. If it's too large or small, then change your print size setting.
      The main thing is to have the template width the same as your A arm hole spacing or the A arm won't fit over the studs.
      The template is available from Guldstrand, but the same problem exists, you need to verify the hole spacing since these templates get photocopied and that can enlarge or shrink it a bit.
      David
      David
      Flo-rida
      and height? How low should the lower bolt holes be in relation to the factory?
      1993 Camaro Z28
      2001 Camaro Z28
      1969 Camaro
      Quote Originally Posted by Project69
      Irrelevant if you use the template as instructed with the confirmed hole spacing. Just make sure they the template has the 6.5" spacing. Not only are the holes lower, but more rearward for increasing the caster.
