Results 1 to 9 of 9
Thread: 73 Nova Swaybars
11-07-2007 #1
- Nov 2007
- 5
73 Nova Swaybars
Hello. I am new to this forum and I am reading different things about rear sway bars.
I am thinking of purchasing ST Suspension sway bar set Part#52055.
I will also install sub frame connectors.
Stock 73 Nova. Original 350 V8 2bbl. Original Turbo 350 Trans. Rebuilt steering and suspension OEM style bushings. Front swaybar stock < 0.70 inches. No rear sway bar. Added Ralley Rims 14x7. BF Goodrich P215/70R14. Daily driver.
Does anyone have experience with ST Suspension?
Do you recomend installing rear swaybar?
What brand of sub frame connector do you recomend?
I have also purchased a Weiand 177 Powercharger, its been sitting around since I started with the home remodel 4 years ago ( I bought it with the loan for the home remodel ) but that will be installed much later. Like after I finish with the home remodel. Wife wants walls and is tired of looking at 2x4s.
As the car is it's a little squirilly on the freeway, and I would like to correct that.
Thanks for any help.
Dan
11-07-2007 #2
- Nov 2007
- 35
Do not go with a rear sway bar. Most of the rear kits are crap. You would be alot better of switching the front to Hotchkis hollw front swat bar. It is a good design, light and makes an amazing difference.
pozziracing.com will tell you why you dont want to use a rear sway bar. I put a hellwig rear bar on mine and it helped nothing, if anything made the car more unpredictable traction wise. Just go with subframe connectors, if you don't believe me I will sell you my Hellwig kit for $50.00 and you can find out for yourself.
11-07-2007 #3
- Nov 2006
- 106
you may want to also look into the guldstran mod my cars a 74 and i have done the suspension and i love how it handles im running 550 springs up front with the g mod and the hotckis hollow sway bar and 250 rate speedway springs in the rear no sway bar very perdictable if not a little on the stif side but i think a ton of the stiffness is my kyb shocks
i have the comp eng subframe connectors you can see them from the side but they are extreemley easy to install my friend has the jegster ones on his firebird and they look to be the same as the comp ones i have
josh
11-07-2007 #4
- Nov 2007
- 35
Yeah take the kybs off and go with bilsteins you'll be way happier, I know I was!
11-08-2007 #5
- Nov 2007
- 5
Thanks for the replies
I'll purchase the Hotchkiss front swaybar!
11-08-2007 #6
- Nov 2007
- 5
Originally Posted by recklessnova
What are 550 springs up front?
What is a "g mod"?
What are 250 rate speedway springs rear?
Dan
11-09-2007 #7
