    Page 2 of 2 FirstFirst 1 2
    Results 21 to 28 of 28
    Thread: Car security
    1. #21
      La Plata, MD
      Pepper spray alarm system
      All right here is what you need to add to your garage security system. I have used these in the past for training military personnel and they work very well and don't leave residue. I have personally used the ceiling mounts and wall mounts, i really like the ceiling mount because you can either drop all four cans at the same time or individually so if the bad guy keep violating the alarm it keeps dropping cans. just my two cents.
      Bruce
      http://www.stopthecrime.com/products.htm
      1968 Pontiac Firebird
      LT1/T56
      Bruce
    2. #22
      Mountain View, CA
      Nice!
      True T.
      My blog
    3. #23
      Jul 2007
      Calgary, Canada
      Quote Originally Posted by Blaster11
      Bruce
      Thats a new thought, looks interesting!
      Dave
      68 Corvair coupe
      65 Impala SS
      64 Corvair Rampside
      62 Corvair Greenbrier
      Asst. daily drivers
      http://www.sourceboards.com/
    4. #24
      Melbourne, FL
      Bruce
      Sweet... This is the ticket. Use the larger 4000 sq/ft system in a 1200 sq/ft garage. Only question is what does this spray do to the car?? Paint, interior, rims, tires, etc .... ????
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
    5. #25
      Here's a slightly more passive approach, these are getting cheaper by the day. http://www.costco.com/Browse/Product...=12&lang=en-US
    6. #26
      Mountain View, CA
      Bruce
      Ahh, but how to keep a 120lb Bullmastiff from tripping it?
      True T.
      My blog
    7. #27
      Jun 2005
      Raleigh, NC
      I normally use about 4 vice grips clamped to the channel on the garage good, plus a couple of junk screwdrivers through the holes. Unless they tear the garage door down, there is no way they are getting in to steal my ****.
    8. #28
      La Plata, MD
      Quote Originally Posted by Damn True
      Actually that is pretty easy. Most all passive motion detectors can use what they call a "pet zone" basically what you do is mask off the lower portion of the lense of the motion detector which will leave a area of several feet high off the floor where pets and non climbing critters can operate/move around. When done properly the masking is undetectable by the casual observer, this is also done for problem areas like heating and cooling vents which can cause false alarms due to the extreme difference in temperatures.
      Bruce
      LT1/T56
      Bruce
