    Results 1 to 12 of 12
      mo
      Propane Chevelle at SEMA
      I have asked this another thread, but it's getting lost.
      Anyway, does anyone what block they used to build the motor, i have searched the web all morning, and can't find a block (SBC) that will go that big. A website or comapnay name would be great
      Thall shall fear no amount of boost, For thy bottle is with me.......
      May 2002
      Northern California
      I did look at the engine but its had to tell from just pictures.
      The heads look to be like the LS type.
      Have you tried a search on the Foose sites? I will try later.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      May 2002
      Northern California
      dude google search first page....its not Rocket science... LOL just kidding. It just came to me. ROFL
      WOW makes great power, I guess Hank Hill has something....
      ENGINE TYPE - Haigh Blocks Small Block Chevrolet
      FUEL - Propane Powered
      DISPLACEMENT 527.6 CID
      BORE 4.320²
      STROKE CRANKSHAFT 4.500² Custom Billet 1-off
      BORE CENTER 4.500²
      COMPRESSION 13.5:1
      HORSEPOWER 1000+
      TORQUE 800+
      BLOCK - Haigh Blocks 10.250² Custom Tall Deck
      SPREAD PAN RAIL BLOCK - Haigh Blocks
      OIL SUMP/OIL TANK - Haigh Blocks
      INTAKE - Haigh Blocks Custom Cross Ram Injection
      CON RODS - Haigh Blocks 6.800² Billet
      CAM DRIVE/VALVE SPRINGS - JESEL
      VALVETRAIN/RETAINERS - JESEL
      SHAFT ROCKER SYSTEM - JESEL
      PISTONS - JE
      CRANK - Custom Billet Stroker 1-off
      CYLINDER HEAD - GMPP Splayed Valve
      HEAD GASKETS - Custom one off by SCE Gaskets
      CAMSHAFT - GS Products
      VALVETRAIN - JESEL Custom 60mm Roller with Cam Belt Drive
      HEADERS - Chris Bresnahan Tri-Step Tri-Y 1.87/2.0/2.5
      UNDERCAR EXHAUST - Chris Bresnahan Custom Designed 4.0 Oval
      CUSTOM RADIATOR COOLING - Be Cool, rated for 1200 HP
      TRANSMISSION - G-Force T56 6-speed, custom rated to 1200 HP
      FLYWHEEL - Centerforce Sintered Metal 6-Puck Single-Disc
      CLUTCH - Centerforce Billet
      INJECTION - Propane Performance Industries, Link & Prins
      FUEL TANKS - Propane Performance Industries
      FUEL SYSTEMS - Prins Alternative Fuel Systems
      IGNITION - MSD Ignition Multi-coil
      ECU - Link
      LIGHTWEIGHT battery - Braille
      STARTER AND ALTERNATOR - MSD
      OIL PUMP - Johnson's High Performance
      DRY SUMP PUMP - Johnson's High Performance
      LUBRICANTS - Pure Power Lubricants
      OIL FILTER - Pure Power Lubricants
      Full page with info....
      http://www.autoblog.com/2007/10/31/s...e-by-mothers/2
      mo
      Quote Originally Posted by MrQuick
      BORE 4.320²
      BORE CENTER 4.500²
      COMPRESSION 13.5:1
      HORSEPOWER 1000+
      TORQUE 800+
      PISTONS - JE
      ECU - Link
      Thanks, I searched Haigh racing blocks, and nothing came up.
      May 2000
      Would one want to build a sbc that big just from bragging purposes?
      Just build a bbc.
      Boston, MA
      Quote Originally Posted by MarkM66
      I thought that was the point of SEMA
      ~Ryan
      Apr 2007
      North Port, FL
      Just build a bbc.
      when you get to cubes that large, what is the differentiating factor that makes it a SBC and not a BBC?
      current - 93 RX7 Twin Turbo Brilliant Black - awaiting LSx engine swap
      previous - 95 TransAm Red, 383ci Forged LT1/4, FMS 238/245 cam
      previous - 2000 BMW 740IL Black
      previous - 95 VR4 Twin Turbo Pearl White
      May 2002
      Northern California
      In this case the price it would require to get there. It cost twice if not three times more to build the SBC version. Everything is custom.
      But I agree, with equal HP and TQ i'd rather have the SB.
      May 2000
      Quote Originally Posted by got_hp?
      Price and ease of build. Tons of off the shelf parts to build a bbc bigger then any sbc.
      Mar 2003
      Kirkland, WA
      It should still be lighter than the big block though.
      James
      -1969 Camaro Sport Coupe
      -1996 Z28
      -2005 Silverado
      Webpage
      Quote Originally Posted by rocketman
      Google it you find lots of info... Seems to be boat and sprint car stuff,... http://www.rlsmarine.com/Products/pa...minum%20Blocks
      Southern Indiana
      Cant be a sbc with that bore center
