      Arlington Heights, IL
      Electric or mechanical fuel pump?
      i have a Holley blue pump laying around but it's old. Im running a 396 with big cam and more compression. Should i use my electric pump or get a mechanical? Im not sure if it makes a differance but it will be driven almost everyday.
      thanks
      Jesse
      1969 Camaro under construction.
      1967 firebird. 6.0/t56. Ridetech stage 2. Moser 9 inch. Forgeline wheels.(SOLD)
      Los Angeles, CA
      Go for a good mechanical pump. Unless you go with a bypass regulator, the fuel pump will be noisy as hell and not last all that long.
      Newbury Park, CA
      Agreed. A Carter street pump should work great.
      Do i still need to use a fuel pressure regulator? I have one allready so if I can use it that would be cool unless its really not needed.
      Aug 2001
      Connecticut
      Most mech. high performance pumps require a regulator.
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      Sep 2007
      Edmonton, Alberta
      http://www.racepumps.com/
      May not fit your budget, but it will handle anything you can throw at it. Great if you have future upgrades planned.
      bbcc
      Sep 2007
      Hampton Bays NY
      I have a mechanical race pump with regulator and have a 496. I had a problem with the pump and race pumps replaced it right away.
      Vinnie Allegretta
      A Winner Never Quits...A Quitter Never Wins
      www.fquick.com/vinz68
      Feb 2007
      Do not buy the Howard so called race mechanical pump. It wont last a week. Then you will be asked to pay $90.oo for an upgrade kit. Its worthless junk.
