      Oct 2007
      orange county, california
      removing the t56
      im trying to remove the t56 from my lt1... none of this is in the car, it is on the floor in my garage. i have taken off all the bell housing bolts and all bolts on the outside that hold the LT1 and t56 together.
      i have been able to pry the t56 about 2 or so inches away from the lt1, it will twist a little and move around in all directions but i cant get the two to seperate completly. I think something inside is still holding thme together.
      i need help so i dont break anything trying something stupid.
      please go easy on my stupidity, this is my first engine / tranny project ever. thanks
      justin
      "What is each day but a series of conflicts between the easy way and the right way?"
      69 camaro, daytona blue. LS376-495 (Hotcam LS3), TR-6060 6-speed
      Tubular control arms with coilovers
      Oct 2007
      seriously, no ones ever removed a t56?!?!?! come on!
      i read some where that you have to remove a pin that hold te tranny to the engine once you have it a bit seperated, but i see no pin. any ideas?????
      Walla Walla, WA
      I've not removed an LT1 T56 with the push style clutch, so can't advise you based on actual experience. However, I'd be very surprised if there were anything designed to keep the tranny from coming out. Is it possible that the throwout bearing is hanging up on the input shaft or the input shaft bearing retainer sleeve?
      Have you removed the slave cylinder and looked inside the bellhousing?
      Failing anything else, I'd call Tyler at ATS www.t56kit.com and see if he has any suggestions.
      Mike Kelcy - '68 Camaro with some stuff done to it.
      Oct 2007
      Quote Originally Posted by Mkelcy
      thanks, got it.... sneaky little ******* that it was!
      Walla Walla, WA
      Glad you got it. Thanks for reporting back too.
