    Results 1 to 11 of 11
      Oct 2007
      orange county, california
      your opinions please...
      So i have a 95 pontiac trans am LT1/T56 that im dropping into my 69 camaro. This is my first engine build and it will be a daily driver.
      here are the mods im doing:
      Long tube headers
      2.5 inch dual exhaust
      custom CAI
      Jegs 1.6 Roller Rockers
      Compcams CC-305 cam 114 lobe seperation
      computer tuning, removale of all emissions programing
      I am also replacing all the piston rings, connecting rod bearings, and crankshaft main bearings.
      I was curious as to what your thoughts are as to my HP and TQ output with this setup.
      And also as to what you think i may be able to hit in the Quarter. I have a set of (i believe) 3.23 in the rear and posi-taction. i will be getting 3.73 later, or do u think 4.11s would be better? Daily driver remember!
      thank you very much guys!
      "What is each day but a series of conflicts between the easy way and the right way?"
      69 camaro, daytona blue. LS376-495 (Hotcam LS3), TR-6060 6-speed
      Tubular control arms with coilovers
      Fontana, CA
      400-425 HP, good TQ with a flat curve. mid to upper 12's with traction. I should also ask about any tb or manifold work.
      Nick R.
      Oct 2007
      Quote Originally Posted by 6'9"Witha69
      unfortunatly those parts i mentioned above have taken over my entire budget for the time being, but eventually im thinking a 54mm throttle body, and maybe an LT4 intake manifold
      but both of those are gonna be some time off.
      Burnaby, BC, Canada
      I know some LT1 guys who put down about 340rwhp (about 400 crank) with the same cam and similar setup.
      I say it could run a mid to high 12 depending on traction.
      A TB should help, but the LT1 manifold should be fine as long is it is port matched to the heads and TB.
      BTW: good job on your porject, I was checking out the other thread.
      1969 CAMARO RS
      Project pics of my '69
      Lateral-G Feature Page
      don't re- ring it unless you are going to properly joan the cylinders, they will never seat properly and you will be unhappy.
      Oct 2007
      Quote Originally Posted by hotrdblder
      Joan???
      first engine build for me so i dont quite have all the terminoligy down.
      Phoenix,Arizona
      he meant "hone" i believe, which is basically putting a cross hatch in the cylinder walls(with a ball hone) to better seat the rings to them.
      Brian
      -1972 Nova
      -1968 Camaro
      -1990 Iroc Camaro
      Oct 2007
      Quote Originally Posted by 70TWO NOVA
      oh haha yeah im actually doing that... should have caught that lol
      anyways thatnks for the advice though, appriciated
      theres right and wrong ways to hoan, on budget or not i would have block washed and tq plate hoaned buy a good builder, then assemble everything yourself, there are way too may issues with ring seal and blow by etc
      Dunwoody, GA
      No, sense in going to an LT4 intake if you are using LT1 heads. That's a complete waste of money. Send your heads and intake to this guy when you have the money. Lloyd does fantastic work. www.eportworks.com
      Trey
      ~ Jon Hammond
      Sep 2002
      San Jose, CA
      Some opinions
      1) Don't waste your money on the 1.6 rockers. If you think you need more rocker, you really need more cam.
      2) At the point in time you are re-ringing the engine and doing bearings you might as well go for a full rebuild. Dump the crappy factory hyperutecnic pistons for some forged units, and balance the rotating assy.
      3) What computer setup are you planning on using?
      4) the LT1 intake manifold actually ouflows the LT4 intake... it just does not match the LT4 head port. I would suggest spending some money on headwork.
      A few years back I did a CNC head/smog-legal cam/shorty header package on a 95 Camaro that pulled over 400RWHP when done. Headwork goes a long way.
      Just call me Brett
