Results 1 to 10 of 10
Thread: Hard Shifting TKO-600
- Oct 2007
- 3
Guys, I’ve got a TKO-600 with about 1,500 miles on it since installation, and I’ve noticed recently that it’s sometimes very difficult to get into first or second gear when stopped.
It seems to occur after a long run, and if I roll up to a stoplight at low speed, I can progressively downshift into any gear including first, with ease. But let the car stop rolling, and I literally have to force it into either gear.
I’ve gotten into the habit of hitting fourth and third, and then trying second and first in an attempt to align the synchros, and it seems to work most of the time, but there are times when it’s all but impossible to get into low gear. I’ve also put the trans in neutral, let the clutch out to spin the input/cluster, and then pushed it in, and went into first, and that sometimes works too.
I’ve got the original Synchromesh fluid in the trans, and plan on changing it soon, but I don’t see that as a major cause. The clutch fully disengages, and there aren’t any alignment issues that should be causing this.
I’m thinking this is something synchro related, and I’ve driven a few other cars with TKOs and hadn’t experienced this, so I’m guessing I have an isolate case. It doesn’t seem to do it when it’s cold, mostly after a long highway run, but I really don’t have enough miles on it to tell for sure. This is otherwise a GREAT transmission!
Have any of you guys experienced anything similar?
