Results 21 to 40 of 55
Thread: '70 Camaro Build
11-28-2007 #21
- Oct 2007
- Pensacola, FL
- 136
Being to close to the beach does not help either..... This car lived most of its life in Panana City Fl.....
Originally Posted by HectorM52
I'm going to lower the frame horns 2" just behind were the bumper brackets bolt to the frame.
Originally Posted by amargari
11-28-2007 #22
- Jan 2005
- Dallas TX
- 1,633
Started as one of the rare "Tooroof" models. Nice work so far.
11-29-2007 #23
- Nov 2007
- LONGISLAND,NY
- 53
looking good cant wait to see it finished
OUTCAST PERFORMANCE....70 BUICK COMING SOON!!!!!!!
11-29-2007 #24
- Nov 2005
- 257
thanks for keeping us up todate with the project
11-29-2007 #25
- Oct 2007
- Pensacola, FL
- 136
Well.... I go the frame welded tonight..... but I'm kind of pissed at myself.... If you look in the pictures I had two lines. The lower of the two was my original mark and the top was the second. Well dumb ol' me lined everything up with the original mark.... so It looks as if the "Z" is going to only be 1.5" instead of 2"....
01-06-2008 #26
- Oct 2007
- Pensacola, FL
- 136
Not much for updates.... but I did push the car outside to clean out the garage so I snapped a couple of pics..... I'm waiting on a few part to come in so I can start building the rear 4-link.
02-15-2008 #27did you ever get the parts for the 4-link
1972 Camaro ( my retirement money hole )
1985 GMC ( future plan pro tour build for the wife )
1992 Isuzu pup bagged, bodydrop, shaved everything
2013 GMC Single cab 4/7 drop
02-15-2008 #28
- Oct 2007
- Pensacola, FL
- 136
Yes I did.... Have not had a whole lot of time to work on the car since both of my girls keep passing some bug back n forth....
I have the lower bars and bag mounts mounted to the axle (ford 9"). I'm in the process of building the cross member of the front lower mounts. Will post some pics by the end of the weekend...
Ryan
02-15-2008 #29I thought mine was low...that's some SERIOUS tuckage!
What are you going to do for inner fenders?
02-15-2008 #30
- Oct 2007
- Pensacola, FL
- 136
Going to rob the old trailer for the front ones...LOL.... I am going to use trailer fenders. It will help with the fender structure since they are 16ga steel. Still undecided about the back. I'm trying to keep some sort of back seat.... and that is not going to be easy....
02-18-2008 #31
- Oct 2007
- Pensacola, FL
- 136
Here are a couple of slow progress pics....
The front cross member and lower bar mounts.
and a quick shot of the rear... I'll get a better pic when I pull it out for final fitment and welding of the brackets.
02-20-2008 #32
- Oct 2007
- Pensacola, FL
- 136
Thought I'd snap a pic befor sliding it under the Camaro
shot looking thru the rear floorboard
One more looking from the rear.... The whole assembly still needs to come up quite a bit more
02-20-2008 #33
- Apr 2006
- 1,027
not sure whats up, however i would not install the rear control arms at that angle, you need to channel the body and or channel the susp mounting points
02-21-2008 #34
- Oct 2007
- Pensacola, FL
- 136
That is not its final spot.... I did not get around to cutting the stock frame rails to move the cross member up. The top of the exhaust cutouts will be about 1/2" higher than the stock floor in that area.
Originally Posted by hotrdblder
02-21-2008 #35
