    Results 1 to 11 of 11
      Header Application
      Hiya guys-
      Car is a 70 Camaro, ZZ4, T5 w/ manual clutch linkage. Currenty has rusty headers with the bottoms all smashed to ..., well, pretty beat up.
      Was looking for a shorty or mid length header that will clear the clutch cross shaft and snug up really well. I live a mile off pavement in MI, and while it won't be winter driven, the road does get a little knarly in summer if it hasn't been groomed in a awhile.
      Anyway, looking for shorty, or mid length headers that will clear a mechanical clutch linkage. Any suggestions? Even consider a long tube if someone put a good word in for model
      Loganville, GA
      I saw in some mag that Heddman has a 3/4 length header that will clear the crossshaft. I don't have the part number though. Also check Sanderson headers, they may have some that work as well. Good luck.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Aug 2005
      Patterson, NY
      I don't know how they'd compliment your setup, but you may want to look into a set of tri-y headers. They offer more room.
      Thanks for the input, guys, but I think I'm going to go woth a hydraulic clutch ILO the mechanicall linkage (This is a Kiesler auto to manual kit going into the car) Don't really like block huggers, I think that the hydro clutch will give me more flexibility in header selection downstream.
      CHICAGO SUBURBS
      Try a set of Dougs or Doug Thorley headers. 2 different companies, started by the same guy. Great fit, and they sit close to the floor. No problem with clutch linkage. I've installed a couple of Tko's. Hyd. linkage in some. My car has mechanical linkage. Way less headaches.
      Houston, Tx
      I absolutely love my thorley tri-y's. The hug the car really well and are built great.
      Houston, Tx
      I got mine from autoanything.com with free shipping and 10% off. I can get you the coupon if you need it.
      http://www.autoanything.com/exhausts...0A2613851.aspx
      Pittsburgh, PA
      Ill second the Tri-Ys, I replaced a set of Hooker comps this year and there is no camparison. I dont know if they are still available, but mine came with the ball/socket collectors and my ground clearance is better than ever.
      Shane
      These were full length, shortys, or? Have the model numbers you used?
      Pittsburgh, PA
      It doesnt matter which company you purchase from the header number is 375y. They are full length.
      Shane
      Clinton, MS
      SCHOENFELD fit the bill for my project, they fit close to the floorboard and can get them in different primary diameters. I can even take my starter off without loosening the header, the oil filter is a tight fit though. and they are full lenght. Street stock series is what I bought and sent them out for coating. Hope this helps!
